Horn Button Tip
  • Little B
  • Little B's Avatar Topic Author
Horn Button Tip
06 Jan 2008 00:25
#187892
I took my horn button apart recently for troubleshooting and cleaning purposes. There are two tiny ball "bearings" inside there that make the button work. Without them there is no way for the contacts to properly touch to close the circuit.
I found putting it back together to be very difficult because the two springs would fall out of the button as I was trying to line everything up. It was very easy to drop those little balls out too. In fact, after the 2nd time loosing them, I couldn't find the 2nd one. I spent about 2 hours looking for the little bugger. Kaw doesn't offer individual parts for the horn button so I was on my own with trying to find a replacement.
I bought a box of 16 gauge shotgun shells, cracked one open and the balls in it were almost an exact match. During the reassembly process, I lost about 10 more but it didn't matter because I now have thousands! :) Bottom line is that it is now re-assembled and those balls work perfectly! So, if you happen to loose one of those little bad boys, save yourself some serious cussing and just crack open a shotgun shell. B)
1981 KZ750-H2 LTD
  • hydrolazer
  • hydrolazer's Avatar
Re: Horn Button Tip
06 Jan 2008 17:31
#188022
all my shotgun shells have lead in them. now the ones for duck hunting have to have steel shot as required by law. can you identify the shell a bit more for us?,,,thanks
\'79 kaw 1000 ltd
  • rdgrnr
  • rdgrnr's Avatar
Re: Horn Button Tip
06 Jan 2008 17:38
#188024
..you dropped your balls?:pinch: :blink: :blush:
and it took 2 hr to find one? Exactly how far away did it roll away?
Post edited by: rdgrnr, at: 2008/01/06 20:40
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
  • Little B
Re: Horn Button Tip
06 Jan 2008 19:39
#188042
Sure, they are Federal Brand Steel Water Fowl Shot Shells. 12 gauge - 2 3/4" long - 6 Shot - 1 oz
That's everything on the box & I got them at walmart.
rd: Nope, it took two hours before I gave up looking for it. :lol:
1981 KZ750-H2 LTD
  • hydrolazer
Re: Horn Button Tip
07 Jan 2008 05:37
#188085
hey,,,thanks for the great tip!!
\'79 kaw 1000 ltd
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Horn Button Tip
07 Jan 2008 06:33
#188106
i used to take shot gun shells and 22 shells apart when i was a kid,id be a little too worried about that shell going off in my face these days though:S
  • Little B
Re: Horn Button Tip
07 Jan 2008 08:46
#188121
That's why I soaked it in water first. ;) Also, if you stick to hacking at the top of the shell, you won't hit any gun powder anyway since it is at the base of the shell.
1981 KZ750-H2 LTD
  • Rich
  • Rich's Avatar
Re: Horn Button Tip
07 Jan 2008 10:25
#188135
you could also just buy some #6 steel shot from a reloading supplier. There are several out there.
That's an interesting fix, who'd have thought?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Horn Button Tip
07 Jan 2008 18:50
#188193
hacking?:blink: we used to just peel the ends open with a screwdriver and dump everything out!young pyros!:P
  • jordan
  • jordan's Avatar
Re: Horn Button Tip
07 Jan 2008 19:10
#188199
screw that, it takes alot of 22 rounds to blow up an atc! Thats why they sell gun powder in bulk for reloading:whistle: :whistle: :whistle: :whistle: :whistle: :whistle:
hillbilly 4th of july- homemade firework(lots of powder)stuffed into the cylinder of atc with wick coming up through the spark plug hole, then caulked shut! Plus a full tank of gas!!!
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • coppertales
  • coppertales's Avatar
Re: Horn Button Tip
11 Jan 2008 13:34
#188751
The only way a shotgun shell will go off is if you hit the primer. Just take a knife and cut the shell in half in the plastic part....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
