Small battery
- Blowntrc5
Small battery
18 Jan 2006 19:26
Hello all!!
I'm looking to use a YUSA 12V - 1.2AH sealed battery on my now kick only 1979 KZ650D. Other then the dim headlight at low rpms, will this work? I will also be doing the coil mod to my Accel coils.
Thanks,
Doug
Thanks,
Doug
- BSKZ650
Re: Small battery
18 Jan 2006 19:54
why so small? and what about the charging system
77 ltd1000, current rider
76 kz900, just waiting
- Blowntrc5
Re: Small battery
18 Jan 2006 20:45
I'm trying to keep the weight down, and space hard to come by(custom frame).
The charging system seams fine, I would just rather use a small battery instead of a capacitor(sp).
Thanks,
Doug
Thanks,
Doug
- dutchz
Re: Small battery
19 Jan 2006 00:35
I'm running something similar - kick only. No problems here...
1974 Kawasaki Z1
Stock front hub and rear axle.
- 79MKII
- Love Them Kaws!
Re: Small battery
19 Jan 2006 20:29
My brother went to kick only on his KZ1000 and went with the smaller battery for weight savings with absolutely no problems. He also has all stock lights and electronic ignition. Shouldn't be a problem for you.
The Kaw List:
- loudhvx
Re: Small battery
20 Jan 2006 09:30
Blowntrc5 wrote:
Your bike should be able to go completely batteryless, with a capacitor, as you said. I've done this on my bike as well (but I had to bump start since the 550's have no kick). I didn't even notice the lights getting dim at stops (I use two 35W bulbs). If you notice the lights getting dim, check the resistance/voltage on your fuse box. Bad connections there are a weak spot on the 650's.
Having a small battery should be no problem at all. My friend used one on his 77 650 (because the 77 can't go batteryless) for the same reasons and had no problems.
Thanks,
Doug
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Blowntrc5
Re: Small battery
20 Jan 2006 18:59
Thanks, for the info!!!
loudhvx,
Very nice scoot!!! I just got done powder coating my frame and swingarm that same green!!
Doug
loudhvx,
Doug
- loudhvx
Re: Small battery
21 Jan 2006 11:17
yeah, I wish my buddy never sold that bike. He regrets it too.
You have any photos? Put them up when you get a chance
1981 KZ550 D1 gpz.
Other links.
Other links.
