77 650 rectifier
  • zippoman
  • zippoman's Avatar Topic Author
77 650 rectifier
18 Jan 2006 16:02
#18530
my rectifier gets pretty hot after a short time, is this normal? It seems like its charging ok but the bike has other issues so its hard to tell. Thanks
  • GargantuChet
  • GargantuChet's Avatar
Re: 77 650 rectifier
18 Jan 2006 19:27
#18579
I'm not sure, but I tend to think that they give the thing big cooling fins for a reason. The job of a voltage regulator is basically to waste all of the juice that isn't being drawn by the normal accessories. I wouldn't be surprised if they get warm after you've been riding for a bit, since at cruising engine RPMs the alternator is probably kicking out a good bit of "extra" electricity.
I'll try to remember to check mine after a ride tomorrow. We should get some decent weather, so I'm looking forward to it!
  • loudhvx
  • loudhvx's Avatar
19 Jan 2006 09:14
#18665
The 77 650 uses a different design. It's not the type that wastes the excess. It uses a seperate rectifier and regulator. Any rectifier will get hot when it handles a lot of current.
  • GargantuChet
19 Jan 2006 09:57
#18673
Grrr... Thanks for catching my mistake. And I was looking forward to having a good excuse for an afternoon ride. I'll just have to blame the weather and ride anyways!
  • Garn
  • Garn's Avatar
19 Jan 2006 11:19
#18680
On the topic, any one know (year & model) when Kawasaki changed to a Regulator/Rectifier unit?
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
  • Tower_Monkey1
  • Tower_Monkey1's Avatar
19 Jan 2006 11:40
#18681
I believe it was the 78 model year. My 78 KZ650C2 has the all in one reg/rect unit. Wayne
78 KZ650C2 Dyna ignition and coils,Pod filters,4-1 Kerker,CBR Tail Light,Drilled front dics,Custom front fender,1/4 fairing.
  • DanOz7Five0
  • DanOz7Five0's Avatar
19 Jan 2006 14:49
#18726
I will second Towers answer. My 77 had the seperate reg/rec but these 78s I picked up had the combo
  • zippoman
19 Jan 2006 15:30
#18738
thanks all, I was just wondering, even the wires are a little bit warm.
