accel coils
  • School Teacher
  • School Teacher's Avatar Topic Author
accel coils
11 Dec 2007 19:58
#184650
any one know how these stack up vs dyna?
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
  • loudhvx
  • loudhvx's Avatar
Re: accel coils
12 Dec 2007 00:43
#184677
Functionally very similar, cosmetically different. Also, the Accel kits cost more but they come with wires and connectors. The mounting holes on the Accels fit some KZ's better than others. They fit the 550 line pretty well, but the earlier 650 mounts are slightly different and need a little grinding to fit. (That is to mount the coils like the stock ones were mounted, without the clamp hardware.)
  • 76 LTD
  • 76 LTD's Avatar
Re: accel coils
28 Dec 2007 13:59
#186757
The ACCELS are as good as the dynas.i like them better simply because of the way the plug wires go on.
  • Spot
  • Spot's Avatar
Re: accel coils
31 Dec 2007 22:02
#187183
Anybody know the coil resistance for an 83 KZ650CSR? I read on another web site that a guy smoked his ignition system with the wrong coils.
Good judgment comes from experience, which usually comes from bad judgment. - Will Rogers
  • loudhvx
  • loudhvx's Avatar
Re: accel coils
31 Dec 2007 22:39
#187185
That bike uses the early KZ electronic ignition. The stock coils should be around 2.5 ohms on the primary. You can use coils that are 2.5 ohm or higher. Standard 3-ohm Accels or Dynas should work well, (but not the "mini" coils, though). If the resistance on the coils is too low, you can smoke your ignition. If the resistance is too high, you may get a weaker spark.
  • Spot
  • Spot's Avatar
Re: accel coils
01 Jan 2008 04:53
#187198
Thanks! You Rock!
