Battery Terminal Corrosion
  • Little B
  • Little B's Avatar Topic Author
10 Dec 2007 05:31
#184385
Do you do anything special to keep your battery terminals from getting corroded? Vaseline or Dielectric grease perhaps? I've heard that if you put that on it will add resistance to the connection. True/Not true?
1981 KZ750-H2 LTD
  • OKC_Kent
  • OKC_Kent's Avatar
Re: Battery Terminal Corrosion
10 Dec 2007 07:42
#184400
Di-Electric grease will keep electrical connections from getting corroded. It does not conduct electricity, which is kind of opposite of what you think it would do. When connections are lubed with it, the grease is displaced and metal to metal contact can happen. The grease keeps oxygen from getting in there and causing corrosion, is my guess.
Years ago I used to put Vaseline on my car terminals, but I honestly can't remember if it worked. Now for the car I use the red and green donuts.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • RonKZ650
  • RonKZ650's Avatar
10 Dec 2007 09:25
#184417
They also make a spray on stuff that works just like paint. Just spray it on your terminals after the battery is all hooked up. I don't know what they call it exactly. I never tried it on motorcycles, but it works great on big automotive batteries.
  • wiredgeorge
  • wiredgeorge's Avatar
10 Dec 2007 09:59
#184426
Either Vaseline or dielectric grease will work fine to stop corrosion. Before you put it on, take a weak solution of baking powder and water and clean the terminals with the solution and a tooth brush. Then rinse and apply the Vaseline or grease. The baking powder solution and corrosion will foam up so you might want to avoid getting it on your skin (chemical resistant gloves are likely a good idea).
10 Dec 2007 10:49
#184432
Thanks :cheer: . Had forgotten about this product. Here's the Permatex version with some interesting information. :)
battery terminal spray
  • Little B
10 Dec 2007 19:28
#184502
That's very helpful guys, thanks!
Edit: WG, do you apply the dielectric grease before or after attaching the + & - wires to the battery?
Post edited by: Little B, at: 2007/12/11 01:24
1981 KZ750-H2 LTD
