LED Turn Signals - Hyper Flashing
  • HerrDeacon
  • HerrDeacon's Avatar Topic Author
07 Dec 2007 17:00
#184146
Hi, I'm in the market for some aftermarket turn indicators and I was looking at some LED ones on ebay. The seller mentions that due to the low power consumption of the LED's that some bikes may experience hyper flashing, or very fast flashing. Has anyone installed LED's and experienced this issue? The seller mentions that you can buy a load resistor kit to solve this problem but I'm wondering if this is necessary? Thoughts?
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: LED Turn Signals - Hyper Flashing
07 Dec 2007 18:14
#184159
Yes, that's what LEDs do. Very common problem, very common post...
I've read that some people add resistors, but all you really have to do is replace your old analog flasher unit with a "heavy-duty" or "electronic" version you find at any auto parts store....
Enjoy!
B)
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • HerrDeacon
08 Dec 2007 03:55
#184196
Thanks Biquetoast, I'll look into the flasher unit you mentioned, good tip.
  • The Milkman
  • The Milkman's Avatar
08 Dec 2007 09:52
#184219
Don't ask for a "heavy duty" flasher, they actually do make a heavy duty thermo one that is made to work with extra added on light, it won't work at all with LEDs. Ask for an "electronic" one, there is a difference.
  • Biquetoast
08 Dec 2007 10:19
#184223
Sorry about that, I didn't know.
Mine said "Heavy-Duty" and "Electronic" on the package.
kz750twins.com
  • HerrDeacon
08 Dec 2007 10:22
#184225
One thing I meant to ask, is there an issue with LED brake lights. I know their power is constant compared to flashers but thought I would ask anyway.
  • Biquetoast
08 Dec 2007 12:29
#184230
It depends on whether or not your bike has a brake light indicator on the dash like mine do.
If so, the indicator works by detecting the draw/load/whatever that a normal taillight uses. Since the LED taillight draws so little, the indicator thinks the light is burned out and blinks constantly.
So, you have a few remedies, including removing the indicator, or adding resistance, or replacing the indicator with a relay or something....
I almost accidentally added the perfect amount of resistance by adding a license plate ring with the tail/brake LED strip. I know it invalidates and failed brake light detection, but I just like to know when my brake light is *on*, more than when it's failed...
Enjoy...
B)
Post edited by: Biquetoast, at: 2007/12/08 15:31
kz750twins.com
  • HerrDeacon
08 Dec 2007 17:56
#184249
Thanks again Biquetoast, I never realized simple LED's could end up being so involved. :)
