Can you use de-ionized water in a battery?
- Little B
07 Dec 2007 13:03
Everything I've read says to only use distilled water when re-filling a battery. Can you use de-ionized water instead?
1981 KZ750-H2 LTD
- loudhvx
Re: Can you use de-ionized water in a battery?
07 Dec 2007 13:20
EDIT: See my second post. I had it backwards.
However, adding water to a battery is only to replace the water that was lost due to evaporation. If the battery was never full of acid, or some acid spilled out, it needs to be filled with acid.
Post edited by: loudhvx, at: 2007/12/07 18:48
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- andoman
07 Dec 2007 14:45
I don't think any water is more pure than distilled. Distilled water is evaporated and then condensed leaving all impurities behind.
It is the impurities (minerals) that destroy batteries.
De-ionized water is exactly what? Process?
It may be ok, but I don't know for sure. You can't go wrong with distilled though
loudhvx is right about the acid level. Only way to know is to do a specific gravity test with a battery tester.
- loudhvx
07 Dec 2007 15:46
Oops, that a big blunder on my part.
Distilled is purer than de-ionized. De-ionized can still contain caontaminants, but just not ionized contaminants.
Best to use only distilled water.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Little B
07 Dec 2007 22:15
Thanks for the help guys!
1981 KZ750-H2 LTD
