wiring harness compatability question
- galaxian
06 Dec 2007 06:02
Ok so i am in need of an entire wiring harness for a 1978 kz1000, which bikes have the same or similitar harness? Should i only be looking for the 73-80 kz1000 models or will the police ones will work as well?
1977 KZ1000A1, 1979 KZ650 C3
- violentvintagecycles
Re: wiring harness compatability question
06 Dec 2007 08:46
I have an 82 kz550 that needed a harness and in haste bought one for an 81. Not even close. I have read a few other posts that say the same thing. My advice, look hard at the wiring diagrams for the same yr bikes and see if anything matches, but I doubt they'll be compatible. Search ebay and salvage yards for the right yr and model harness, you'll be better off in the end.
- galaxian
06 Dec 2007 09:12
Thanks and yes i have been looking for a 78 harness but for some reason they are few and far between.
06 Dec 2007 09:21
There all hard to find, just keep plugging away, and try the salvage yards. ALL of them if you have to. And make sure they understand the make model and yr you need. I found mine in a conneticut salvage yard, ill try and get the name for you, they did good by me.
- roy-b-boy-b
07 Dec 2007 04:32
I had a friend to have one made and it was a great job.
I'll try and get the info of where he had it made.
Do a search for motorcycle wiring harness and see what you come up with. Roy
- quader98
10 Dec 2007 16:58
is yours an A2?if so,there are three models with the same "wiring harness main".the A2,A2A and the C1A which is the police acording to zedder
Post edited by: quader98, at: 2007/12/10 20:02
Post edited by: quader98, at: 2007/12/10 20:03
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
82 GPZ 750 R1
