fuse box problem and more problem
- diablo666mew
03 Dec 2007 13:18
i have a 1981 kz650 it has a fuse box with 2 glass . no i just got the bike it is not running so i checked the compression i am get around 110 psi on all plugs so i checked my spark no spark i no because i had a friend stick his finger in it while i tryed to started it and he did not get schocked luckey ( also my start buttton does not work so i had to bridge the starter to the battary the next part might be y that button does not work not sure yet maybe you can tell me ))but i went to check the fuses and i saw 1 was broke but the more i look some wires going to it was cut the white wire is cut and goes in to the fuse box comes out white and blue after going in the the fuse box now the othe the red and white wire comes from the battart to the fuse box and it has the blown fuse and come out white and black and is unplued frome some where it has a plug on the end like i said the head light workes the start button does not and i have 110 comppression and i have no spark help
- The Milkman
Re: fuse box problem and more problem
03 Dec 2007 19:16
First off welcome to the site. I know it trivial, but doesn't anyone introduce themselves anymore?
I'm wondering, with the starter button not working,, are you even getting power to the coils? Are you lights and such working? Usa a test light and check for power at the primary side of the coils, the primary side is the side that has a common connection in the wiring harness. Also, is the kill switch in the middle postion for on?
You do know that you are going to be asked to put you bike information, ie: year, engine size and model in your sig line. You can do that by clicking on you "Profile" in the panel on the right side of every screen.
Ride safe
Ride safe
- diablo666mew
03 Dec 2007 21:58
yea i dont think i am get power to the coil i will make sure when the sun comes out my lights do work any other idea thanx
