Looking for help!
  • BoZ650
  • BoZ650's Avatar Topic Author
  • 77 KZ650 with 4 to1 and pods,Dyna Coil and Dyna S
Looking for help!
17 Nov 2007 04:02
#181428
OK.I just installed the wiredgeorge coil mod along with dyna coils and dyna s ignition.All parts are bolted in.Can anybody explain to me in simplified terms as how to time the bike prior to starting it?Do I move the whole dyna s plate or just the two black pick up modules??Sorry to ask but ive have never timed any thing before and I dont want to ruin anything.Oh yeh,The directions state to install rotor with the magnet facing left.I didnt exactly see a magnet,I assumesd the little circle in the plastic on side of rotor was "the magnet".Is that correct.77 KZ650b.Thanks Guys!
Tony
77 KZ650 With 4 into 1 header,Air pods,Dyna Green coils,Dyna S Ignition and WiredGeorge coil mod!
  • OnkelB
  • OnkelB's Avatar
Re: Looking for help!
17 Nov 2007 04:58
#181431
You are correct, the little circle on the rotor is the magnet - when the 1/4 marks on the advancer are pointing up the magnet should point left.
When timing 1/4 you move the whole DynaS plate, when timing 2/3 you only move the right hand pickup module. You might not need to adjust 2/3 once you have 1/4 timed , but check it anyway just to be sure.
77 KZ 650 B1, 82 GPz 1100 B2.
  • BoZ650
17 Nov 2007 06:18
#181437
Thanks so much OnkelB.Ive already had one fire,I didnt want anymore mishaps.
  • Bluemeanie
  • Bluemeanie's Avatar
17 Nov 2007 07:03
#181446
I followed the static timing directions and it was spot on. I know I should but it runs soooo good I haven't put a timing light on it yet.
  • BoZ650
17 Nov 2007 08:25
#181453
Thanks Blue,I plan on tackling both,1st the static and then with the gun but one step at a time.Some times my head moves quicker than my skill level!!Thats when I screw stuff up,ya know???
  • BSKZ650
  • BSKZ650's Avatar
17 Nov 2007 11:36
#181478
make sure you check to make sure the correct wires go to the correct coil, mine was backwards from the factory
77 ltd1000, current rider
76 kz900, just waiting
  • BoZ650
17 Nov 2007 12:33
#181482
BSK-Is that just a matter of switching the two wires if thats the case??Thanks for the heads up!
  • The Milkman
  • The Milkman's Avatar
17 Nov 2007 14:20
#181492
It's all a case of "the hurrieder I go the behinder I get", we've all been through that.B)
