Coil Recommendation?
  • Bicycle Lee
  • Bicycle Lee's Avatar Topic Author
09 Nov 2007 10:24
#180310
So I'm looking to purchase a new set of coils for my 1978 KZ1000 police bike....anybody have any recommendations?
1978 KZ1000 police
  • mariozappa
  • mariozappa's Avatar
Re: Coil Recommendation?
09 Nov 2007 10:29
#180314
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • Bicycle Lee
09 Nov 2007 10:33
#180317
this is really gonna make me sound dumb, but can you NOT put 3 ohm coils on that bike? Everywhere I look I see that the 'late-model' coils are 2.2 ohm...
and also...does it matter that I'm running points?
Post edited by: Bicycle Lee, at: 2007/11/09 13:34
1978 KZ1000 police
  • loudhvx
  • loudhvx's Avatar
09 Nov 2007 10:48
#180321
There are many variables. I'm not familiar with the P bikes.
The following assumes the dwell angle is about 180 degrees on the 78 KZ1000P, but I don't know that for a fact (most points KZ's are 180 deg.)
If you have a ballast resistor, you'd have to know what resistance the ballast is to make the right choice.
If you don't have a ballast resistor, and you're running points, you want 3.0-ohm to 4.0-ohm coils. The lower the ohms, the faster the points will pit and wear. 3.0-ohm is about as low as you'd want to go. If you ever convert to electronic ignition, the 3.0-ohm coils will work for that too, so the 3.0 is a good choice for the most future options. If you know you will never get rid of the points, the 4.0-ohm coils will make the points last longer.
If you have a ballast, and are considering going to electronic ignition, the ballast will be removed and the 3-ohm coils will work.
So for most applications you'll want the 3-ohm coils and remove any ballast.
Post edited by: loudhvx, at: 2007/11/09 13:51
  • Bicycle Lee
09 Nov 2007 10:56
#180323
so ANY 3 ohm coil? or am I looking for something in particular?
1978 KZ1000 police
  • loudhvx
  • loudhvx's Avatar
09 Nov 2007 11:48
#180332
Most people get the Dyna 3-ohm or Accel 3-ohm. They have to be full-size coils. You can't use the "mini" coils.
Here are the Dyna's:
www.z1enterprises.com/detail.aspx?ID=210
Here are the Accel's with the wire kit:
Accels at Dennis Kirk
The Accel's cost more, but I like them. I usually wait for better deals on Ebay or elsewhere.
  • Bicycle Lee
09 Nov 2007 11:59
#180333
thanks....what about spark wires....I've heard conflicting arguments between suppression and copper core. Right now I have copper...
1978 KZ1000 police
  • loudhvx
  • loudhvx's Avatar
09 Nov 2007 20:51
#180422
To reduce RF noise you would use suppression wire, or resistor plugs, or resistor caps. The RF noise shouldn't affect a points ignition, or your bike in general. It may affect more sophisticated electronic ignitions and other electronic devices.
The suppression doesn't affect the spark too much. A good motor would show no difference. The only time spark energy makes much difference is in a motor in bad shape or bad carburetion, or a poorly designed motor.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
10 Nov 2007 05:53
#180444
Edited to avoid a highjack. Started a new thread.
Post edited by: rstnick, at: 2007/11/10 19:23
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
