KZ 750 Twin Coil
- snakebiteaz1
KZ 750 Twin Coil
02 Nov 2007 19:48
Hello, i just bought a 1979 KZ 750 Twin, wanted to see what years would work with this model.. Thanks Mike
- Biquetoast
- King Jeremy The Wicked
Re: KZ 750 Twin Coil
04 Nov 2007 07:05
snakebiteaz1 wrote:
But do yourself a favor and buy a new coil.... you won't regret it...
You mean what years of coils? I would suspect most of them.Hello, i just bought a 1979 KZ 750 Twin, wanted to see what years would work with this model.. Thanks Mike
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
04 Nov 2007 07:31
Z1E lists several Dyna coils for KZ750 twin, so assure replacement being correct size/ohms.
Z1E coils
Z1E coils
- steell
04 Nov 2007 09:33
3 ohm Accel coil will bolt right on and work, I have never used the Dyna coils so I have no idea if they are bolt on.
- ronjones
04 Nov 2007 10:27
Ya need to modify Dyna coil, by drilling out the metal end mounts 90*,and you may have to elongate the bolt holes on the mounting bracket. It's also a bit of a tight fit. Had to do this to get the dynacoil to work w/my '82 M1.
- Biquetoast
04 Nov 2007 15:13
ronjones wrote:
I have Dynas on both my 750s. I don't remember having to modify my mounts. Ok, if anything, I had to grind down a tad of the metal on the stock bracket. Other than that, it was a direct fit. Yes, tight, but direct.
kz750twins.com
kz750twins.com
- ronjones
04 Nov 2007 19:45
Biquetoast wrote:
That's my story and I'm sticking to it
I've actually had 2 dynas on mine, Toast. I got a 3ohm one used and the metal end tabs had apparantly already been drilled out for bolt holes @ 90* to the "grommeted holes, and bolted right on, w/a little elongation of 1 mounting plate hole. At the time I thought it came that way but when I bought, the correct, 2.2 ohm coil, the 90* bolt holes weren't there and I had to drill them. Because the coil mounting ends are made of metal plates, they came out looking like U-holes.ronjones wrote:Ya need to modify Dyna coil, by drilling out the metal end mounts 90*,and you may have to elongate the bolt holes on the mounting bracket. It's also a bit of a tight fit. Had to do this to get the dynacoil to work w/my '82 M1.
- snakebiteaz1
- Biquetoast
05 Nov 2007 03:10
ronjones wrote:
Interesting. I think I get you now.
For everyone else's reference, the *standard* replacement Dyna coil for an *early* twin with POINTS is *probably going to be the 5 Ohm (black) one. If you have done any mods to the ignition system, you needs may vary, of course....
By the way, I have a 3 Ohm on my twin with a Newtronic, and a 5 Ohm on the bike with points. I did not need to re-drill the holes or anything like that, and the wires ended up going out the left side.. instead of up or down... which it sounds like yours are doing, Ron...
... I got a 3ohm one used....but when I bought, the correct, 2.2 ohm coil...
kz750twins.com
kz750twins.com
- grace1
05 Nov 2007 03:22
hi mate there is a guy on usa ebay sells them most weeks , have the right size hole centres etc , they are new look identical to a kawa one i look each night here type in kz750 under motorcycle parts
good luck
good luck
bendigo australia, gold mine country
MY COLLECTION 1978 B3 KZ750 AND 1980 GS1000G
- ronjones
05 Nov 2007 05:02
Biquetoast wrote:
Ok now I understand what you did vs what I did. If I had used the predrilled "grommeted" holes my plug wires would, indeed, have come out one side or the other. Perhaps, I didn't diddle w/the orientation enough, but I just couldn't seem to get the coil to fit, by having the plug wires comming out the side. I even considered just mounting it somewhere, else, more convienent, on the frame. It must have something to do w/the frame differences of our different models. The 750CSR, seems to have a few quirks, not found on the earlier models.
ronjones wrote:... I got a 3ohm one used....but when I bought, the correct, 2.2 ohm coil...
