Accel plug wires- catalog vs autozone
  • Randy
  • Randy's Avatar Topic Author
02 Nov 2007 09:38
#179295
Have a 76 kz900 w/1015cc wiseco, andrews stage2 cams,
& accel ingnition. Needs plug wires & catalog offers 2 8.8mm @ $45. Can purchase 4 8mm at auto parts store for the same price. Any reason I should not save the money & go with the 8mm plug wires?
  • BSKZ650
  • BSKZ650's Avatar
Re: Accel plug wires- catalog vs autozone
02 Nov 2007 16:21
#179356
as long as its a solid core wire, it will work
77 ltd1000, current rider
76 kz900, just waiting
  • Randy
02 Nov 2007 18:21
#179373
thanx for the responce... I think I'll save the money
  • wiredgeorge
  • wiredgeorge's Avatar
03 Nov 2007 16:05
#179472
They sell an "off road" or "racing only" kit at the autoparts store. It will have TWO long wires with four plug boots on the ends. You cut the wires somewhere in the middle and install rubber coil covers first, then install the metal contact pieces that fit into your coils. I think you cut back insulation and bend the conductor over the outside of the insulation, stick the metal coil connector on the end so that it makes contact with the conductor and then crimp it, if memory serves. I don't like to use the Accel wires unless I use their coils as they are hard to fit into regular 7mm holes in a Dyna coil.
