cant get spark at plug
- dusterdude
14 Oct 2007 08:45
82 ltd 750.couldnt get engine to turn over at start button.tied the starter interlock wires together to bypass the interlock.i get power at the coils and to the ignition module,dont get anything past the module.btw,i jumped a starter button across the starter relay to get the engine to turn over.any ideas?how can i test the module to be sure its good or bad before i decide to buy a new one?thanks
- arobsum
Re: cant get spark at plug
14 Oct 2007 09:34
i believe the coil fires by taking away the ground...the moment it loses ground the field collapses and the spark occurs....try something along this line, see if it helps. DO NOT hold the ground connected for long...the coil will get very hot and probably quit working. just ground the wire manually then release quickly.
- steell
14 Oct 2007 11:49
It takes less than .01 second to charge a coil, so all you have to do is scratch the wire against a ground.
- dusterdude
14 Oct 2007 12:26
thanks for the replies,arobsum,you pointed me in the right direction.apparently the ic ignitor wasnt grounding thru the wiring harness,i cut the wire out of the harness and grounded it directly to the battery,now i have spark.next,put gas tank on and throw gas to her and see what happens.
