Won't Start
- obiwaynekenobi
Won't Start
13 Oct 2007 17:24
Hi, I am trying to help a friend get a 1979 KZ1000st running so she can sell it. It belonged to her husband who passed away about a year ago. With the key/switch on, nothing happens when you push the start switch. It has a full charge and power to the ignition switch. The fuse is good, but I was told to test the rectifier and I did. It is getting voltage in, but appears to not have voltage out. I want to make sure this is the problem before I buy another rectifier. I did the rectifier resistance test listed in the Repair manual and had hi/low resistance in one direction and switched leads and had no resistance the other. Any Ideas? Are there any other things to check? Thanks
Re: Won't Start
13 Oct 2007 17:36
Pull in the clutch.
- RetroRiceRocketRider
Re: Won't Start
13 Oct 2007 17:49
650ed wrote:
To elaborate a little on this, the clutch lever has a safety switch that it contacts when at rest and prevents the bike from starting w/out first pulling the lever in towards the handlebars. It basically keeps the operator from starting the bike while it's in gear, which could potentially lurch away from him/her and do some serious damage. :pinch:
BTW, welcome to KZr.
Post edited by: RetroRiceRocketRider, at: 2007/10/13 20:49
Pull in the clutch.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- mark1122
- Keep twisting it
Re: Won't Start
13 Oct 2007 19:46
if u are useing the clutch,the next step would be to test for power at the switch.u can take the switch off the handlebars and put a multimeter positive lead from the power side of the switch and the other lead to ground and see if there is power there with the key on.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Re: Won't Start
14 Oct 2007 08:27
Would check wiring from the starter button (black color, I think) through lockout switch to starter relay.
Assure good connections at bullet connectors to and from lockout switch and into starter relay.
Would also check battery positive connection to starter relay.
Good Luck!
Good Luck!
- Warthog
Re: Won't Start
16 Oct 2007 10:58
This happened to me as well and it turned out that I had disconnected a wire when removing the tank. I felt like a complete idiot. I would look for loose wire first before I unscrewed or disconnected anything.
This message brought to you by Hotdog
