spark?
  • shoslo
  • shoslo's Avatar Topic Author
spark?
07 Oct 2007 06:51
#175017
having problem getting spark '76 kz 750 b1 checked fuses and battery going to start chasing plug wires any help please
Post edited by: shoslo, at: 2007/10/07 09:51
  • Skyman
  • Skyman's Avatar
Re: spark?
07 Oct 2007 08:54
#175029
Okay, let's start with the basics. Do you have a repair manual (factory, Clymer, Haynes)? There should be a section in there on how to test your coils.
Do you have a multimeter to test the resistance in the coils?
Check the primary leads to your coil to make sure they are connected and not corroded.
Do you have a points ignition? Have you checked the points?
West Linn, OR
