- Thank you received: 1
starter just clicks - anti climactic rebuild
- bison
05 Oct 2007 08:29 #174705
by bison
1979 SR650 D2
starter just clicks - anti climactic rebuild was created by bison
I recently just finished assembling my 79 SR (after complete disassembly and resotration) and the other night after finishing up the wiring, all my lights and stuff worked, but when I hit the starter button, all I hear is a "click". So I immediately thought battery issues. So I charged up my new battery again (it was already charged) and still the same thing.
So I'm wondering if the starter is having trouble engaging.
The engine turns over fine with kick starter. And I know the starter worked before I took the bike apart.
My wife is losing confidence in me (She told me I would never get the thing running again!!) Help me prove her wrong!!
1979 SR650 D2
- OKC_Kent
- Thank you received: 20
05 Oct 2007 08:38 #174707
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic starter just clicks - anti climactic rebuild
It may be the starter relay. Turn on the key, pull in the clutch and jump the relay lugs. If it spins over then you know the relay is bad.
Oklahoma City, OK
- trippivot
- Thank you received: 3
05 Oct 2007 08:41 #174708
by trippivot
Replied by trippivot on topic starter just clicks - anti climactic rebuild
tap on the starter soleonid the tend to stick sometimes
it is a easy fix if you need toreplace it
- bison
05 Oct 2007 11:13 #174730
by bison
1979 SR650 D2
Replied by bison on topic starter just clicks - anti climactic rebuild
to be honest I don't know where the starter relay and solenoid is. Are they both on the starter itself?
thanks
thanks
1979 SR650 D2
- OKC_Kent
05 Oct 2007 12:06 #174735
by OKC_Kent
Oklahoma City, OK
Probably under the left hand side cover. Follow the big wire from the battery positive terminal, it connects to the relay/solenoid.
Oklahoma City, OK
- gpzrox
06 Oct 2007 05:33 #174869
by gpzrox
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
Replied by gpzrox on topic starter just clicks - anti climactic rebuild
Same symptoms, mine was/is the starter. to test, take out the starter, hook up jumper cables to the positive lug and negative to the mounting hole, other negative to your motorcycle battery, and touch the positive lead to the battery. If it spins hard, then you could be OK, but lets check something else first.
take the two long bolts out so the endcaps can come off of the starter. If the endcap opposite of the gear is full of black powder, then you need to replace your brushes.
- bison
08 Oct 2007 10:36 #175213
by bison
1979 SR650 D2
Thanks for the help guys. I jumped the lugs and sure enough the starter kicks in. But my starter button on my handle bar doesn't work.
Would that still be the relay, or did I just do a bad job of wiring?
Thanks again, I'm a beginner when it comes to the electrical stuff
1979 SR650 D2
- bison
08 Oct 2007 10:36 #175214
by bison
1979 SR650 D2
1979 SR650 D2
