Weak to no fire on kz650 1978
  • cr916
  • cr916's Avatar Topic Author
27 Sep 2007 21:17
#173272
Hello could anyone out there help me with my 78 kz650. I have put new points, condensors and also new coils in it. But it still has weak to no fire, can anyone help me?
  • wiley90
  • wiley90's Avatar
Re: Weak to no fire on kz650 1978
27 Sep 2007 21:47
#173275
First i would have bought a dyna electronic ignition. But, now that you spent your money on points. Check that you have 12 volts at your coils. Make sure your points are set properly (correct gap). Next take out your points throw them in your trash bin and install a new electronic ignition! I bought mine from a place called cycle recycle out of indiana off their web site and would highly recommend these people. Great price and fast shipping. Dean
1976kz900
  • BSKZ650
  • BSKZ650's Avatar
28 Sep 2007 04:41
#173296
Sounds like low voltage to the coils, WG has a coil mod listed that cures the problem, but first check the voltage at the battery and then at the coils to see if you have a large drop.
Are the coils NEW or some new to the bike coils
77 ltd1000, current rider
76 kz900, just waiting
  • bill_wilcox100
  • bill_wilcox100's Avatar
28 Sep 2007 08:07
#173313
Ditto with BSKZ650 and wiley90... except that I still have use for stock points.
In addition, have you tested/changed your high voltage wires, your spark plug caps and your spark plugs? Don't forget to test your wires (Green and Black) between the Points and the Coils.
By the way, could you add your year, model and location in your signature. It will help others to respond to your questions. ;)
Best of success.
Post edited by: bill_wilcox100, at: 2007/09/28 11:10
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
28 Sep 2007 10:37
#173329
Will the engine crank up and run?
Is the battery strong enough to spin the engine over with the electric starter?
Absent more info, am thinking problem may be be from low (insufficiently charged) battery, or a bad battery, or poorly grounded battery. :)
  • cr916
28 Sep 2007 19:35
#173413
It does have a weak battery on it and I have had to use a booster pack on it to turn the motor over. The ground cable looks chewed up and somebody has put a car end on it. I would have liked to get rid of the points but the guy that owns the bike is cheap. The bike has new coils that I bought from Z1 Enterprise, Thank you for the help.
  • AK82kz440
  • AK82kz440's Avatar
30 Sep 2007 11:54
#173724
Replace or at least make sure the battery is fully charged and that the connections are good. Even if the battery has enough juice to turn the starter the compression in the cylinder makes it harder for the plugs to spark. At least this is my experience with my 82 kz 440 LTD
