Regulator/Rectifier for Z900-A4
- Sorf
11 Jan 2006 16:36
G'day all,
New member here!
have had a search through the files on this subject and it seems almost any other 12v R/R will work.
As my original has died and kwaka part is $$$$$$$$$$$
I've found a unit off a Honda CX500 (part SH232-12) now i've found out so far that the SH232 will work OK.....but not sure what the significance of the -12 on the end is??
Will this work as well or install any different to the SH232 bit??
Thanks (Hopefully)
Glenn
Post edited by: Sorf, at: 2006/01/11 19:40
New member here!
Thanks (Hopefully)
Glenn
- KZQ
- Administrator
Re: Regulator/Rectifier for Z900-A4
11 Jan 2006 18:45
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- savedrider
- 1975 Z1-B 900
11 Jan 2006 19:54
KZCSI wrote:
Ditto that! Jeff sells a nice little unit that's plug-and-play for your bike.
Get right or get left! <*{{{><
- loudhvx
11 Jan 2006 22:51
Sorf wrote:
In order to tell if it will work, you'll need the wiring diagram from the Honda. Personally, I would stay away from any Honda electrical parts (that goes for their cars too). They fail more than often Homer Simpson.
G'day all,
New member here!
Thanks (Hopefully)
Glenn<br><br>Post edited by: Sorf, at: 2006/01/11 19:40
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Sorf
11 Jan 2006 23:22
Well, I have looked at Jeffs R/R earlier and it would seem the way to go, the only drawback is the postage alone will cost more than this one (assuming this one is OK)
The other choice I have here is a Kwaka Z1000e unit which also sounds like it should work.
Best price I've found so far for a OEM Kwaka is $330USD
which is more than this little black duck is gonna pay.
- Garn
12 Jan 2006 01:10
Welcome to the forum Z buddy!
Sorf', I think SH 232-12, with the 12 just meaning 12V and the SH standing for Shringular or something!. Guys in UK swear by that rect/reg. They usually get it from a H**da "Superdream". I have asked several questions about it. They just want to say it works well and the earth is green. I was unable to find out if it is a five wire or a six wire (both work).
I have had a lot of luck with secondhand ZXR6 units that I fit with the green or white plug and mount in the regulator position. They are about Aus$80 at wreckers.
Regardz
Regardz
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Sydney Australia
- Sorf
12 Jan 2006 03:54
G'day Garn,
Thought I might pop in here and learn some more!
I wanted to ask on that other forum but didn't want to tread on anyones toes. A lot of the info I found was from the UK, I can get one of these for around $45AUD actually and the Z1000e for a couple of bucks more, so it sounds pretty tempting.
- wiredgeorge
12 Jan 2006 06:12
Sorf - My first bit of advice for you is to watch out for a guy named Garn... He is a foreigner of the worst sort (Aussie I think) and hangs upside down all the time making him very odd indeed! Bwhahahhaa
Second bit of advice is that the reg/rec you speak of is sort of ubiquitious and sounds like the same unit used on later model KZs from the late 70s onwards. It is made by the company whose name someone mispronouced... shimoogoszonotoat... err never mind. Anyway, it should have about six wires coming out. The three yellow can be hooked up to the three wires coming out of your stator which currently terminate in your plug/junction box on the blue connector. There will also be a white/red, brown and black. I can't recall the specific function; that is, where the wires need to be hooked unless I look at my KZ1000 wiring diagrams which are in manuals in my shop right now. Seems to me that the white/red would be your battery connection, the brown would be the hot main feed and the black a ground connected to your starter solenoid but I could very well be wrong so check a KZ1000 wiring diagram for any late 70s model with a consolidated regulator/rectifier. I would also recommend you don't hide the thing when you mount it... get it in some airflow as heat is what kills them. Also, if you buy used, there is a troubleshooting procedure in the KZ1000 manual that is helpful but the reg/rec needs to be mostly wired into the bike to do the checking I think... resistance checks and voltage checks and the like...
- Sorf
13 Jan 2006 01:29
Thanks for that advice wiredgeorge, both on the R/R and that Garn guy!..............I'll be careful from now on
Sounds like I'll go down this path, as there all made in same place, I'm guessing one off a Hoonda can't be that bad.
When you say don't hide it, I'm assuming the under battery box or standard rectifier possies won't be a problem?
Post edited by: Sorf, at: 2006/01/13 04:36
- dutchz
13 Jan 2006 07:55
Welcome Sorf. I think WG covered it pretty well, as usual. I did as similar upgrade on my bike, using a 86 Ninja R/R. Here's the link to how I installed it:
kzrider.com/component/option,com_joomlab...atid,4/id,8892/#8892
Loudhvx recommended I installed a 15V inline fuse on the brown wire to protect the circuits in case something went wrong. I just checked the model# on it it's SH530-12K, I only paid 30 bucks for it. Good luck...
1974 Kawasaki Z1
Stock front hub and rear axle.
