Stator install - a little help
  • squints
  • squints's Avatar Topic Author
26 Sep 2007 15:12
#173023
ok, so i've bought a new stator for my ride and it has finally arrived. looking for any words of wisdom before i jump right in and mess something up. Anybody have any tips, pointers, common mistakes they've made?
i've read the manual a few times and it really doesn't sound too bad, even for me, but still i thought i'd throw it out there and see what i get.
thannks!!!
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
  • donthekawguy
  • donthekawguy's Avatar
Re: Stator install - a little help
26 Sep 2007 23:16
#173115
Put a oil pan under the housing before you start and make sure you have a new gasket. Other than that it is easy-until you break a bolt taking the stator out. :P
Post edited by: donthekawguy, at: 2007/09/27 08:40
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
27 Sep 2007 04:00
#173125
And while at it, would consider replacing the --
grommet
  • squints
27 Sep 2007 15:42
#173220
cool, for that grommet, since i'm installing a new peice i jsut run the wires through it right, no cutting soldering required? thanmks for the tips.
Upstate NY
  • squints
29 Sep 2007 13:48
#173533
the old stator was hooked up with three connectors which i had to disconnect to remove the stator. Now, do I just directly install the new stator using the long yellow leads provided or do i cut the wires and make three new connections?
Upstate NY
  • squints
29 Sep 2007 13:49
#173535
Upstate NY
  • squints
29 Sep 2007 13:49
#173536
Upstate NY
  • pgrojean
  • pgrojean's Avatar
  • Pete
02 Oct 2007 10:41
#174156
I can't believe that I actually have something to offer here:) Make sure that you seal the wires where they come through the grommet otherwise you'll get a pesty oil leak (and oily left shoe/boot). I replaced my stator cover twice with new gaskets to stop the leak until I figured out the oil was coming through the holes that the wires were running through. Also seal up the grommet.
KZ1100 LTD - 83
R1200 C - 98
RD 250/350 73
KLR 650 - 06
XS 650 - 79
  • patmann
  • patmann's Avatar
02 Oct 2007 11:50
#174159
pgrojean, Good point!!;)
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
