Installed dyna ignition and coils.Now
  • ricerocket
  • ricerocket's Avatar Topic Author
25 Sep 2007 11:04
#172773
I recently installed a dyna ignition setup and a oil cooler kit.Now the bike is hard to start.All most like the battery is running down.
  • loudhvx
  • loudhvx's Avatar
Re: Installed dyna ignition and coils.Now
25 Sep 2007 11:10
#172774
The Dyna uses twice as much power as stock. Check your voltage while the bike is revving. If you are using high power halogens andthe Dyna ignition, you may be draining the battery at lower speeds.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
25 Sep 2007 20:22
#172869
Ignition timing set properly?:whistle:
1977 KZ1000 A-1
  • AR15Ron
  • AR15Ron's Avatar
25 Sep 2007 21:01
#172877
Has the WiredGeorge coil mod been done? Check your voltage at the ignition coils.
Pretty much has to be one of 3 things, the other 2 already mentioned:
Not charging properly/low voltage.
Low voltage at the coils.
Or the most probable maybe? Timing set incorrectly.
  • ricerocket
26 Sep 2007 16:08
#173035
i dont no exactly where to set my ignition guess i have to take it to a shop for that.But when running it was smoky adjust timing forward i think stopped smoking.
  • ricerocket
26 Sep 2007 16:09
#173036
Also going to 12600cc have all parts need to install it.Winter job.
26 Sep 2007 16:57
#173048
Instead of spending money at the shop, I would suggest using the money to purchase a strobe-type timing light.
It's fun and super-easy to check and adjust the ignition timing, whether points or electronic, and simultaneously watch the advancer unit operate back and forth.
Actually, the ignition timing should have been done when the Dyna ignition was installed.
And compared to an winter overbore job, ignition timing is a 60 second piece of cake. :)
Post edited by: Patton, at: 2007/09/26 20:00
  • ricerocket
26 Sep 2007 18:39
#173065
i might as well pick one up seems i should get to know this stuff.
  • AR15Ron
  • AR15Ron's Avatar
26 Sep 2007 21:20
#173104
If you set the timing at the time of installation according to the Dyna instructions it should be pretty close. Get yourself a timing light and you will know for sure. I found mine was 100% dead on just set according to the dyna instructions. Been awhile since I did that but I think you needed a multimeter? Did you set it like that when you installed it? If not then you will need to adjust the timing, probably lucky it runs at all :)
  • BSKZ650
  • BSKZ650's Avatar
27 Sep 2007 05:00
#173140
you do need a timing light to set it the right way, and you do not need the high dollar ones either, do you have a book of any type for your bike? need that also
77 ltd1000, current rider
76 kz900, just waiting
