1980 750H bare bones for mattylight
11 Oct 2019 18:24 #812278 by ccammo
Replied by ccammo on topic 1980 750H bare bones for mattylight
Thank you for your quick reply martin_csr, I've purchased a KZ750 '79 and ALL of the wires have been removed and I'm trying to start it before I take it completely apart, so I know what I'm working with. The previous owner did however give me all the wire bundles so I am slowly putting the pieces back together. Would you have any recommendations on soldering over crimping? I'm thinking of just soldering everything with a shrink wrap over it to seal it.
The '79 does have a starter solenoid but I'm missing a voltage regulator/rectifier and the turn signal relay. Purchasing that soon along with a new instrument cluster and starter switch.
Thanks for all your help!
  • loudhvx
  • Topic Author
11 Oct 2019 20:25 - 11 Oct 2019 20:31 #812283 by loudhvx
Replied by loudhvx on topic 1980 750H bare bones for mattylight
In my opinion, solder only has limited use on a harness. Connections at switch contacts are often soldered by the factory, like on the back of the ignition switch. Almost everything else is crimped. Crimping lasts a lot longer. Solder erodes the wire, and the heat weakens the copper. Solder gets wicked into the conductor and creates a rigid wire such that the strands are prone to break off from vibration or motion.
The only other place I use solder is if i have to join wires together in a harness like at a t intersection . The way to do it is to run the intersecting wire parallel to the other wires for a bit then bend the wire away at a point where there is no solder. Then I wrap the solder joint so it is supported by the rest of the harness against any movement. That way any movement only affects a clean stretch of wire. Stranded wire can take a lot of movement without breaking.
Page 15 has a 78 diagram with a starter solenoid (and starter).
www.kzrider.com/forum/4-electrical/17274...ght?start=280#579749
Last edit: 11 Oct 2019 20:31 by loudhvx.
11 Oct 2019 21:06 - 11 Oct 2019 21:07 #812287 by martin_csr
Replied by martin_csr on topic 1980 750H bare bones for mattylight
I do stock type crimps using open barrel terminals & an open barrel crimper >> the crimps are very strong. I already had a HF ratcheting crimper, but the dies were wrong, so I got an open barrel die set from amazon.com. Some components, such as the ignition switch, have soldered connections inside, which sometimes need to be redone. Z1Enterprises.com & CycleTerminal.com have terminals, plastic connectors & crimp tools. Z1Ent also has colored wire. ps: loudhvx knows more about this stuff than I do. I'm kind of a rank amateur in the electricals. hee.
Last edit: 11 Oct 2019 21:07 by martin_csr.
  • loudhvx
  • Topic Author
27 Nov 2019 10:18 - 27 Nov 2019 10:22 #814659 by loudhvx
Mattylight Barebones Bare Bones
1980 Kawasaki Kz750E1 for Trytobuildkzcafe
Kz750E Kz750 E1 Kz 750 E 750E1 750E
Last edit: 27 Nov 2019 10:22 by loudhvx.
02 Feb 2020 08:04 #818407 by LeFunzig
Replied by LeFunzig on topic 1980 750H bare bones for mattylight
Even though this is posted a while back, I'd like to ask one question:
If have been trying to figuring out what the B/W wire from the igniter is for. I guessed it has something to do with a safety feature, as it is connected (with diodes) to the neutral, side stand and lockout switch.
Just wiring this to the ground B/Y is a solution to bypass this?
  • loudhvx
  • Topic Author
02 Feb 2020 08:52 - 02 Feb 2020 08:55 #818412 by loudhvx
LeFunzig wrote: Even though this is posted a while back, I'd like to ask one question:
Yes, if you are wiring a later ignition like from a Zx550 or Zx750, the black/white (or brown/white) wire on pin 3 is the interlock (safety) wire. Just ground it to run.
This diagram is for the 550:
Last edit: 02 Feb 2020 08:55 by loudhvx.
The following user(s) said Thank You: LeFunzig
  • loudhvx
  • Topic Author
29 Mar 2020 08:41 #822104 by loudhvx
1981 Kawasaki Kz750H2 Ltd. for Galaxian
Kz750H Kz750 H2 Kz 750 H 750H2 750H
  • loudhvx
  • Topic Author
19 Apr 2020 11:54 #823679 by loudhvx
1978 Kawasaki Kz200A1 for HouseLudwig
Kz200A Kz200 A1 Kz 200 A 200A1 200A
Batteryless operation requires a switch to turn off the lights in order to start.
19 May 2020 11:34 #826090 by Peanuthead
Replied by Peanuthead on topic 1980 750H bare bones for mattylight
Hey Loudhvx, you are awesome posting these bare bones diagrams! I'm in the last stages of my 440 project. I was wondering if the diagram you made for I_Tig_in_piece will work for me. I'm using a new, universal ignition switch (4 wire), start button, and turn signal switch instead of the OE parts.
  • loudhvx
  • Topic Author
20 May 2020 09:14 #826145 by loudhvx
That diagram is for a 1980 Kz440A1. Is that what you have? If so, then it should work. If yours is a later model, you will need the wiring for the electronic ignition.
20 May 2020 10:06 #826149 by Peanuthead
This is where I'm actually having the problem. The engine is an 82 but the diagram I found that matches correctly is for an A2. Is the 82 LTD considered an 82 A2?
20 May 2020 10:40 #826156 by martin_csr
Is the motorcycle an 82 or just the engine? Is this a chain drive or Ltd Belt?
