coils
  • paradon
  • paradon's Avatar Topic Author
coils
24 Sep 2007 16:39
#172635
Is it ok to mount my ignition coils vertical (83 550m1 shaft drive). i am building a custome tank and they are in the way. any help would be great.
  • JR
  • JR's Avatar
Re: coils
24 Sep 2007 18:55
#172662
I'm pretty sure you can mount them any way you like....just as long as they are reasonably well shielded from the elements and not subject to excessive heat... like maybe strapped to an exhaust pipe :P :laugh:
Horizontal, vertical wont make any difference.
Some bikes like the 1300 have them under the seat.
Be sure to post a picture of the finished tank
  • flht1997
  • flht1997's Avatar
Re: coils
24 Sep 2007 19:01
#172664
as long as they are not oil filled, you will be fine
and i mean upside down, oil filled, they will leak. but if you have a more stock motorcycle coil, you are OK
Post edited by: flht1997, at: 2007/09/24 22:03
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • paradon
Re: coils
25 Sep 2007 14:08
#172810
maby a better question, what would you go with for after market coils and wires? i mit just get new of both.
Re: coils
25 Sep 2007 15:43
#172828
Am well pleased with these on Z1 and KZ900 (with 3 ohm coils):
Dyna 3 ohm coils
Dyna plug wires
Dyna has other coils with different ohm usage, so be sure you get the coils with the correct ohms for your particular bike. All available at Z1E. :)
  • bill_wilcox100
  • bill_wilcox100's Avatar
Re: coils
25 Sep 2007 16:53
#172840
Ditto to what flht1997 and Patton said. With Dyna's (not oil filled) you can orient them any way you want.
Yet having said that, I would still try to orient the Dyna’s with the HiVoltage leads pointing down to make them more resistant to water/rain penetration. If down is not possible then I would try to orient the Dyna’s to have the HiVoltage leads point towards the rear of the bike for the same reason (that's how I did it). ;)
I am sure many have been installed them opposite to my recommendations and they have worked just fine, but I prefer not to fight nature or the laws physics more often than necessary. Why? Don't ask... :unsure:
Best of success!
Post edited by: bill_wilcox100, at: 2007/09/25 19:55
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
