i want one of these... where?
  • requiem
  • requiem's Avatar Topic Author
22 Sep 2007 09:13
#172172
i want one of these - where do they come from?
kzrider.com/archive/images/public/img-1091866227.jpg
Post edited by: requiem, at: 2007/09/22 12:19
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: i want one of these... where?
22 Sep 2007 09:48
#172174
The taillight in that pic is on Mark Wings '77 KZ650C, and it's from an early 90's ZX6 600 Ninja.
I have the same taillight as in that pic that I'll be installing on my KZ650, and it was from a '92 ZX6 600 Ninja.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • requiem
22 Sep 2007 09:54
#172177
nice. he said something about using it for the turn signals as well... i 've seen that a lot, but it's usually on modern LED tai-lights. i like this one because it's not as gaudy as some I've seen... do you think you can do the turn signals with this light as well?
  • StreetfighterKz
  • StreetfighterKz's Avatar
22 Sep 2007 13:22
#172202
Yes, as long as the light assembly you get has 2 dual filament bulbs you can intergrate the turnsignals. You can either get a "Tail Intergrator" or a trailer wiring box.
I have a Zx12 light on my 1000 and has intergrated turnsignals with the brake and taillights still functional.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • seanof30306
  • seanof30306's Avatar
30 Apr 2008 01:36
#210234
Is that tail light mounted upside down? I've looked for a similar one, but all the ones I can find look inverted to that one.
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
30 Apr 2008 06:20 - 30 Apr 2008 06:21
#210261
Yes!
At least mine is and I have the same one.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 30 Apr 2008 06:21 by rstnick.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
30 Apr 2008 18:50
#210376
Here is how I mounted the ZX6E tail light, and made a license plate bracket:
The light is held on with two brackets bent into Z shapes, with holes in each end of the Z. One side of the Zs is mounted to the tail's mount, the other end of the Z to the light.
The license plate bracket is a separate piece. A flat piece of aluminum with four holes. Two line up with the rear fender mounts, the other two the size/spacing for the license plate.
I have a spare inner plastic fender put in place of the stock chrome fender. It's cut short and turned around facing backwards:
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
