black wire from rectifier
  • 13thlevel
  • 13thlevel's Avatar Topic Author
17 Sep 2007 19:53
#171236
found the black wire from the rectifier not connected. does this connect to the battery ground or to the frame or does it matter. would this create major problems if not connected? my battery had completely boiled off all of it's electrolyte and the bike has fried 4 coils before i noticed this. where does the wire connect? -thanks
could the previous owner have done this to hide something else wrong?
Post edited by: 13thlevel, at: 2007/09/17 22:58
  • oldkaws4ever
  • oldkaws4ever's Avatar
  • Have no regrets...... You only live once.
Re: black wire from rectifier
17 Sep 2007 20:07
#171241
on my 74 z1 900, i have my black wire from the rectifier grounded off at the negitive side of the battery:) . Hope this helps
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
17 Sep 2007 21:50
#171258
Yes...it connects to Your battery...according to the diagram though,it connects to the positive side.I've eliminated all the original components on my bike,so I can't look at Mine to be sure.
Looking at that diagram again,if You're talking about the black/yellow wire,then that one does connect to the negative side of the battery.
Post edited by: Sandy, at: 2007/09/18 00:52
Post edited by: Sandy, at: 2007/09/18 00:56
1977 KZ1000 A-1
  • oldkaws4ever
17 Sep 2007 22:13
#171259
sandy, i have the combo rectifier/regulator from z1 enterprise's. Mine hust had the green plught that connects to the control block, and a black wire, which i asuned is the ground. I have had this wire connected to the negitive side of the battery for over 500 miles with no problem's, knock on wood :whistle: :whistle: :whistle:
Post edited by: oldkaws4ever, at: 2007/09/18 01:14
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
17 Sep 2007 22:18
#171261
My aftermarket combo has 7 wires in total...2 go to the neg side,and 2 to the pos side.The other 3 go to the dynamo(alternator).
I was told that it was a "Heavy-duty" unit,hence the doubled-up connections to the battery.
1977 KZ1000 A-1
  • loudhvx
  • loudhvx's Avatar
18 Sep 2007 11:17
#171347
If the wire is brown, but dirty, it may appear black. The brown wire gets switched 12v from the ignition switch.
The black/yellow wire goes to negative on the battery (as was mentioned).
If the brown wire or black/yellow wire is left unconnected on the regulator (not rectifier), it will overcharge and burn out your electrical system.
