Dyna 2000 rever, not limiting
- mark1122
- Keep twisting it
13 Sep 2007 05:23
the rev limiter on my new dyna 2000 (with 2.2 grey coils)is not working.has not since install.any advice ? ive put 1500 miles on it and did not attempt to hit the limit untill this week,so i did not know there was an issue. bike runs fine otherwise. see sig for bike.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Sandy
- Fly High,Tony
Re: Dyna 2000 rever, not limiting
13 Sep 2007 07:28
Mark...are You sure that You don't have it set to the max rpm,on the setting,on the one end of the module?
The little cut-out ON that switch is a little on the wide-side,and maybe You have it set to 16k by mistake? I think that's the highest setting just past the lowest setting(one click away).
1977 KZ1000 A-1
- mark1122
- Keep twisting it
13 Sep 2007 14:03
no but thanks for the tip Sandy. i just double checked and it was on 8500, so i bumped it up to 9000 and i'll see if that makes any dif.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
