Electronic Ignition
  • robhavens
  • robhavens's Avatar Topic Author
Electronic Ignition
11 Sep 2007 15:41
#170035
Anyone convert their points and condensors to Electronic Ignition? What manufacturer is better? How hard is it to complete the fit?
  • The Milkman
  • The Milkman's Avatar
Re: Electronic Ignition
11 Sep 2007 17:19
#170047
To begin with, what model bike is it... but, you will probably find it unanimous to convert to a Dyna system.
Check on availability here
Ride safe
Post edited by: The Milkman, at: 2007/09/11 20:20
  • steell
  • steell's Avatar
11 Sep 2007 18:59
#170062
Nope, not unanimous, I use KZ440 or 82-83 KZ750 twin factory electronic ignition on my 750 twins, and others here use later model stock electronic ignition on their early model 650/900/1000 fours.
Whole lot cheaper and uses less amps than a Dyna.
Post edited by: steell, at: 2007/09/11 22:00
  • robhavens
26 Sep 2007 16:26
#173040
OK. I have a 78 KZ650 B2. You are saying that I can use a newer stock electronic ignition on the older bike. what model would you suggest I look for?
26 Sep 2007 17:07
#173049
  • steell
  • steell's Avatar
26 Sep 2007 17:08
#173050
80 or new KZ750 four should be a direct bolt on, and someone else here has a 1000 electronic ignition on a 650.
Similar discussion is taking place in This thread
Post edited by: steell, at: 2007/09/26 20:14
  • loudhvx
  • loudhvx's Avatar
26 Sep 2007 17:53
#173055
Early 80's 550 ignitions using mechanical advancers are a direct bolt-in for the 650, also.
