White gauge face plates???
- fixer5000
Re: White gauge face plates???
16 Sep 2007 12:09
easy trick for getting those needles off...dont laugh now ok?? leave the teeny screws on the faceplate and use two teaspoons to pry with.. yes two teaspoons...use the screw tops as your pry points...works great and no mar....steve
1978 kz650b pretty much stock
massachusetts
massachusetts
- brich
26 Sep 2007 21:02
Well i finally found some time to finish these suckers up! I ended up going with the UV spray and some gloss self adhesive paper.
Of course in true fashion i have to take them back apart and make a new backing plate. I used to old black one and the gauges just aren't bright enough for me. Think I am going to get some Lexan or plexiglass and make a new back, or look into different LEDs. The LEDs i bought throw off a wicked bright light forward but not much to the sides. Here are some pics ....
1975 Z1 900, 1075 wiesco kit, web cams, smooth bores, dyna ignition, denco pipe, lester mags, wicked bad rotors, custom gauge face plates .. not much stock left.
- brich
26 Sep 2007 21:03
- bkitchen
- 79MKII
- Love Them Kaws!
27 Sep 2007 17:19
They definitely look great! Do you have a trick for separating the gauges and clamping them back together? That's what scares me the most :ohmy:
The Kaw List:
- brich
27 Sep 2007 19:03
LOL .. i wish i did man! I basically used a thin flathead screw driver and a pair of bent nose needle nose pliers. IT was a bitch getting them apart. It was easier putting them back together as I just crimped them down with the pliers. Your probably going to bend them up all ugly either way.
I bought chrome gauge covers cause it basically covers everything i just made ugly!
Good luck man. I wasn't a horrible experience by any means, just some work. A few things to be aware of ...
Be careful putting the new face on and make sure your surface is clean and you match up your lines for accuracy.
It was tough getting the needles back on so they sit right. You can tell in the pic i was a tad off on the tach! :pinch: No biggie though, I know when to shift and how to set an idle.
