White gauge face plates???
  • brich
  • brich's Avatar Topic Author
Re: White gauge face plates???
14 Sep 2007 21:26
#170679
wait .. u said u used regular matte photo paper? Did u use anything to stick it down or just the screws?
1975 Z1 900, 1075 wiesco kit, web cams, smooth bores, dyna ignition, denco pipe, lester mags, wicked bad rotors, custom gauge face plates .. not much stock left.
  • brich
14 Sep 2007 21:29
#170680
Sleeper .. i didn't forget about you buddy. I will still change that redline marker and get u the files. I just been a bit out of it lately.
  • bkitchen
  • bkitchen's Avatar
14 Sep 2007 21:36
#170681
I got the Lexan from home depot. The font I used is Nosferatu(not sure where I downloaded that from) I just got my chrome gauge covers from Z1enterprises and cut the lexan to fit them. I used spray adhesive to stick the photo paper to the gauge fronts. By the way from an earlier question. To remove the speedo or tach needle I first took out the to small screws that hold the original gauge front on. If you hold it up you can get under it and get at the bottom of the needle better. I "modified" a flat head screwdriver by putting a small notch in the center of the blade. Get under the needle and with a little pressure it comes right off. Here is a closeup of the font. I stripped the paint off of the needle to show the brass underneath. ( I know I need to realign the needle)
Post edited by: bkitchen, at: 2007/09/15 00:45
  • brich
14 Sep 2007 21:47
#170682
Home Depot huh? Nice .. i am there!! I got those same covers too. Interesting, you didn't even use the old cover. Good idea man! May have to steal that idea too! ;)
I was just thinking, I may cut some clear plexiglass to use for the backing of the paper so that the light comes in from behind some through the white paper. It almost seems like that is kind of how kawisaki did them to light up the numbers. Not sure how it will look but may be worth it since I am already putting an insane amount of time into these.
  • bkitchen
  • bkitchen's Avatar
14 Sep 2007 21:50
#170683
Use all the ideas you want that is why I posted them. Now you have me thinking about the lexan backing.;)
  • brich
14 Sep 2007 21:54
#170685
LOL sorry! I had to get at least one original idea in. ;) :lol:
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
14 Sep 2007 22:04
#170688
Where are you guys getting the LED replacement bulbs? I thought the new lights would have to be hard wired in and mounted somehow. Sounds like you found LEDs with a standard bulb base? How cool!
Post edited by: 79MKII, at: 2007/09/15 01:04
The Kaw List:
  • bkitchen
  • bkitchen's Avatar
14 Sep 2007 22:07
#170689
I actually hardwired mine in, I got them at Autozone.
  • brich
15 Sep 2007 07:49
#170711
I got the bulbs from here ...
www.superbrightleds.com/BA9S6_specs.htm
I ordered the 4 LED BA9s Bulbs. I ordered 4 of them in blue. Make sure you select to have them in 12volt so they match the electrical system. I haven't tried to turn mine on yet but I am hoping for good things. I think I only spent like 10 - 13 bucks for the 4 bulbs.
Post edited by: brich, at: 2007/09/15 10:50
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
15 Sep 2007 08:31
#170713
Awesome, thanks!
The Kaw List:
  • btchalice
  • btchalice's Avatar
16 Sep 2007 07:25
#170886
i had a blast making the other one from the other thread im kind of dissapointed i wasnt in this one :dry: B)
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • SLEEPER650
  • SLEEPER650's Avatar
16 Sep 2007 07:34
#170888
COOL I APPRECIATE IT MAN!
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
