Dyna ignition
- ricerocket
Dyna ignition
06 Sep 2007 13:07
I bought a dyna ignition did not come with instructions
Question how do i get my ignition plate off got the plate off but there is a nut,And when i try to remove it it turns the engine over but i need to take it off to fit the new doohickey.that spins.Any one now were there is instructions i need help.
- mariozappa
Re: Dyna ignition
06 Sep 2007 13:23
If I understand you correctly, the (17mm) nut your are turning is on the end of the crank shaft. There should be a 14mm nut on the end of that, which will come out.
That's how it is on my 650 anyway.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- Sandy
- Fly High,Tony
- Bluemeanie
Re: Dyna ignition
06 Sep 2007 19:23
Hold the 17mm nut with a wrench and then remove 13-14mm small nut on end.
Post edited by: Bluemeanie, at: 2007/09/06 22:23
Post edited by: Bluemeanie, at: 2007/09/07 18:32
- ricerocket
Re: Dyna ignition
12 Sep 2007 21:41
I installed the dyna ignition and i am hearing a ping or clicking does not get louder when i rev it.I spoke with a mechanic and he said my timing might be to advanced.
Any thoughtsplease also installed an oil cooler bike now holds almost 5 liters 4.7 to be exact.Runs alot cooler.
- mark1122
- Keep twisting it
Re: Dyna ignition
13 Sep 2007 05:15
u likely have the timing set at 40* .u could try 39 or 38. also check with a timming light to see if the advancer is advancing the timming to the proper degrees at the proper time. the springs are known to get week with heat over time. this will alow the timing to advance earlier and more.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
