Sidestand switch, where connect?
  • Wilde
  • Wilde's Avatar Topic Author
03 Sep 2007 00:23
#168142
Hello,
I have a slight annoyance with my bike which is that the sidestand switch is not physically connected to the sidestand and I cannot see where it should go? The switch functions electrically I just do not understand where to connect the spring on the switch to the sidestand. Since the swith works it is just annoying that I cannot use it...
  • apeman
  • apeman's Avatar
Re: Sidestand switch, where connect?
03 Sep 2007 16:56
#168299
My bikes do not have a sidestand switch, and they are nearly identical to yours. I do not see one on the wiring diagram either. Maybe you should post up a picture of the switch you are talking about.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
  • JR
  • JR's Avatar
03 Sep 2007 18:12
#168309
I would also be interested in seeing a picture. No sidestand switch on my bike either.
  • KZErider
  • KZErider's Avatar
03 Sep 2007 19:01
#168327
Yeah, I think we're gonna need some pictures. Because I have the same model in the works, I did look up in the KHI manual and the Haynes (no Clymer's)and saw no reference to such a switch. I even studied the wiring diagram, to the best of my ability, and saw nothing. Wonder if it's a mod the PO did?
My BMW releases the stand if you stand the bike up and pull in the clutch, but it doesn't seem like that's what you're talking about.:unsure:
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
  • pumps
  • pumps's Avatar
03 Sep 2007 21:37
#168354
No switch on my 79...:blink:
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
  • Wilde
03 Sep 2007 23:17
#168372
Hi, it might be a previous owner fix, but it doesn´t look like it, will post a picture this evening.
  • 810gpz750
  • 810gpz750's Avatar
04 Sep 2007 06:49
#168411
my 84 gpz has one. i elimanated the switch and jumped the wires with a small resister !tada! no more warning indicator.
  • KZErider
  • KZErider's Avatar
04 Sep 2007 07:31
#168424
Went back and looked through the book again and the first model the stand warning switch appears on is the '82 Z750R1. It wasn't in the table of contents nor in the glossary, so I guess it's not that important.:laugh:
  • Wilde
04 Sep 2007 12:03
#168478
Here comes the picture, You can see the tube between the footrest and the sidestand, inside is a switch looking exactly like a brake pedal switch. It also seems not to warn but to shut of ignition, like the kill button.
Post edited by: Wilde, at: 2007/09/04 15:04
Post edited by: Wilde, at: 2007/09/04 15:07
05 Sep 2007 04:07
#168626
Just guessing :unsure: --
Perhaps a modification intended to momentarily kill the ignition when shifting, so as to facilitate clutchless WOT shifts. :)
  • coffeedragon
  • coffeedragon's Avatar
06 Sep 2007 19:06
#169075
What you've got is a sidestand switch wired in by a previous owner. If it looks like the foot-brake switch then it just needs a spring connected from the switch to the kickstand as close to the stand's hinge-pin as possible. You would want to connect it in such a way that it pulls on the switch's spring just enough to engage it but not so much that it deforms the spring.
Personally I would redo the wiring so that the switch just triggers a light on your dash rather than cut out the ignition. As someone who is presently dealing with a large number of demons in my bike's electrical system, the less complicated the system is the happier you will be.
  • Wilde
07 Sep 2007 09:25
#169197
Yeah, I have daemons also, that is the reason I started looking at this switch I will remove it, never felt a need for it. Another daemon is in the ignition lock, which looks not original, only six wires out, should be seven...
