having trouble starting
- armysgtkzrider
26 Aug 2007 01:15
i have a 77 kz650 that i just bought a month ago and no idea when it last ran. the start button does not work and the kick start turns the engine over but no start.
my carbs are clean and getting fuel so what should i do next?
- gpzrox
Re: having trouble starting
26 Aug 2007 03:26
Welcome to the forum.
You need to check for your 12VDC at the ignition coils with the ignition on. Usually the 12v comes from the battery - through the key switch - to the aforementioned starter button - to the coils.
So if your starter button doesn't work, and you get no start, I'd look at the wiring connection for the wire bundle that runs down from that switch. You may get lucky!
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
26 Aug 2007 05:24
Suggestion: If the bike hasn't been used in more than a year, before you continue to try to start it you should change the oil (if you have not already done so). Otherwise, once it does start you'll be pumping who knows what sludge instead of a lubricant and may cause wear that shows up later as other problems. Ed
- outatimeoutlaw
26 Aug 2007 06:39
Yeah man change the oil & do a compression check. Then check it for spark. Also how old is the fuel & what condition is the tank & fuel valve in??
- The Milkman
26 Aug 2007 07:09
By any chance is the kill switch not turned on? I ask because I have personal experience,,, :laugh: :laugh: :laugh:
- The Milkman
26 Aug 2007 07:13
Also, I just noticed this is your first post, welcome to the mad house. Not knowing your experience with a bike, are you pulling in the clutch when you are trying to start it with the button? When you turn the ignition on do the headlight, brake light and such work?
ride safe.
ride safe.
