Why does my Headlight jitter so much?
- cgray34
23 Aug 2007 03:20
Why does my Headlight bounce up and down so much? I know there needs to be a little play(so the filiment doesnt break), but driving at night is really annoying when my light is so moveable?
I've notice that the new bikes dont have the same lights(do they?)? Is there an aftermarket headlight I can put on my KZ brighten the ride and not have to have so much play in it?
- Biquetoast
- King Jeremy The Wicked
Re: Why does my Headlight jitter so much?
23 Aug 2007 04:53
cgray34 wrote:
That could be alot of things. One of my bikes was missing the bottom support (only had the side supports so it bounced alot). Another one has 15w instead of 10w in the forks, so being extra firm, causes the front to be bumpier and makes the like bounce... Then again maybe your light isn't screwed in tight into it's holder ring... and so on...Why does my Headlight bounce up and down so much?...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- Snakebyte
23 Aug 2007 05:16
The little spring inside there keeps it from jittering.
- cgray34
23 Aug 2007 11:37
Little spring? Am I missing something? Where is the spring? Inside the headlight or on the mounting cluster?
- RetroRiceRocketRider
23 Aug 2007 13:22
I'd suggest checking out the diagram for your headlight to see if any of the mounting hardware (screws, washers, bolts, nuts, spacers, etc.) is missing, incorrect, or loose and allowing your headlight to bounce up and down.
Kawasaki Parts Diagrams
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- Norseman
23 Aug 2007 13:24
I think Snakebyte might be referring to the focus adjustment spring which keeps tension between the rim/ring and the headlamp itself.
- udder
23 Aug 2007 14:06Please Log in or Create an account to join the conversation.
