point's are finally shot
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
21 Aug 2007 21:09
#165526
well i wet to start the 900 today and it was a no go. Ive noticed for about the past week it was getting progressivley harder to start. I took of the points cover and realised that the points that fire the 1 and 4 cylender wasn't moving back and forth like the other set of point's were. So im going to replace the points and condensor tommorow. And im also going to replace my rectifier/regulator while im at it.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • nads.com
  • nads.com's Avatar
Re: point's are finally shot
21 Aug 2007 21:17
#165532
Make sure the flat part of the point spring doesn't touch the plate when your done or yu might kick something besides the ....
  • Bluemeanie
  • Bluemeanie's Avatar
29 Aug 2007 08:21
#167106
Make sure you use a light coating (I use synthetic disc brake lube) on the cam to keep rubbing blocks from wearing down.
