regulator/rectifier instalation on 74 z1 900
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
20 Aug 2007 22:27
#165312
ok im finally getting around to swap my old rectifier/reculaor with a one peice combo from jeff at Z1. What's involved in getting the old one off. Im going to put the new one in, because recharging the battery every week or sooner just plain suck's. I hope this fixes my charging problems.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • oldkaws4ever
Re: regulator/rectifier instalation on 74 z1 900
22 Aug 2007 23:53
#165792
OK now im officialy stumped, i went to take off the old rectifier under the battery box, that was a P.I.T.A. Now my question is, the old regulator has 2 bullet connectors and a white plug the plugs into the connector pannel. The new one is a rectifier/regulator, and the only connectors is a green plug for the rectifier that plugs into the connector block, a white wire with 2 female plugs, and a ground wire, but there is no white plug to plug into the conector block. Should i plug everything in and just leave the old regulator in place along with the white plug plugged into the connector block?????????????? IM CONFUSED..................can anyboby help.........................thanks
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
