Where is the fuel gauge on KZ1000 CSR?
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
19 Aug 2007 17:27
On my newest project (KZ1000-M2), I just discovered that there is a fuel level switch in my fuel tank. But I don't see the gauge anywhere. I assume it is missing from my bike. Where is it supposed to be?
Post edited by: Skyman, at: 2007/08/19 20:28
West Linn, OR
- oldcoldankles
Re: Where is the fuel gauge on KZ1000 CSR?
19 Aug 2007 17:36
On my 1981 it is located in the lower part of the tachometer. I am surprised that mine is very accurate and I can always predict exactly how much gas I need to fill up.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
- Skyman
19 Aug 2007 17:44
oldcoldankles wrote:
Duh! Thank you!
I was looking for a gauge, not a light. After reading your reply, I went and looked. Sure enough, there is the fuel light. Didn't notice it before.
Duh! Thank you!
West Linn, OR
- oldcoldankles
19 Aug 2007 20:00
They must have changed over from a gauge to light from '81 to '82 then.
Peachland BC
1981 KZ1000 CSR M1
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
- kzwolfsr
19 Aug 2007 20:21
My 81 LTD1000 has a fuel guage on it. I guess they decided to do that to the CSR's after they did it on the LTD's.
Original man of the Caribbean
- smd
19 Aug 2007 21:25
On my '82 it's a light on the tach, not a gauge, just as you described -- so I figure that's stock.
- Skyman
19 Aug 2007 22:33
smd wrote:
So...when does the light come on? About the same time you need to switch to reserve? Later?
West Linn, OR
- NiagaraZ
20 Aug 2007 18:00
My 78 650 has a low fuel light, it comes on before having to switch to reserve. Actually I've never had to switch to reserve. There seems to be about 5 litres lrft in the tank when it lights up.
78 KZ650 D1
