I lost # 1/4 cylinders on Friday on my 82 Kz1100. Coil primary tests OK at 2.6 ohm. The secondary shows open. I thought when they failed they shorted and were lower resistance (the shop manual says 15-20K). Is this a normal failure, or is my multimeter not capable of measuring? If it is a failure, does anyone have a replacement they can part with? Model is ZC006-TR12V. Thanks for your help, Jeff
