Starter motor
  • pete1952
  • pete1952's Avatar Topic Author
Starter motor
14 Aug 2007 04:13
#163737
I've just bought a KZ650 which runs fine but there seems to be a problem with the starter motor, it turns once then stops, can anyone tell me if this is a typical problem and how I might cure it
  • N0NB
  • N0NB's Avatar
  • Blue handles better
Re: Starter motor
14 Aug 2007 04:28
#163739
Is it the starter motor or the engine that turns onces and then stops? If it's the engine, then the likely culprit is the starter clutch located on the secondary shaft inside the engine. Replacing it requires pulling off the exhaust, pan, clutch and then removing the secondary shaft and replacing the "one-way" assembly (it comes with the machined piece, rollers, pins, and springs). It's not a trivial job, but it's not extremely difficult either.
If the starter motor is stalling out, it can be removed quite easily. Most likely there is a brush hanging up.
Typically, a worn starter clutch makes quite a bit of noise when trying to start the engine because it's slipping under load. Otherwise it's quiet. Is there a squealing/grinding noise?
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • tjettim
  • tjettim's Avatar
Re: Starter motor
15 Aug 2007 03:30
#164013
Most KZ650 riders I know just kick start
their bikes.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Starter motor
16 Aug 2007 13:27
#164289
Welcome Pete.
My starter's been good for 30 years. The starting button might need some work as I have to wiggle it a bit sometimes.
Glad it works too as the rear set pegs I've installed are in the way of the kick starter.
:pinch:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
