Brake light switch
  • Bluemeanie
  • Bluemeanie's Avatar Topic Author
Brake light switch
11 Aug 2007 16:38
#163256
Riding to work the other day and was sitting at a traffic light when I saw someone coming up behind me. When this happens I ALWAYS grab my front brake lever and tap it a few times to make my tail light flash to make sure they see me, this time I noticed that the red light on my dash did not light at first or second pump but finally did. This morning I decided to check it out, when I pump the lever it flashes about 1 out of 3 times. When it flashes both dash and tail flash, when it doesn't niether one flashes. That tells me bulbs are ok. Took the brake lever off and cleaned off 27yo grease and dirt. Pushed button in and out all the way with my finger and it's a little better but not right. Does that switch come out and apart for cleaning or is it junk? Thanks guys
Post edited by: Bluemeanie, at: 2007/08/11 19:39
  • Bluemeanie
Re: Brake light switch
12 Aug 2007 07:58
#163357
I think I got it, the little brass rod sticking out had worn at an angle so I removed the switch and spun the rod around to a fresh side. A little dap of grease on the master plunger and brass rod. Works great now, hope it does not turn back to original spot?
