turn signals not working
  • SebRain77
  • SebRain77's Avatar Topic Author
  • When in doubt, gas it!
10 Aug 2007 03:03
#162945
Just got the bike last night. as far as lights go, all are working, position lights as well. But the turn signals arent flashing. Could it be as simple as a fuse?
Ever hit the pavement? I did, put that gear on!
1977 KZ 650C1 - First bike, ever! For sale - or not!?!?
2004 Z750 - More power than I'll ever need...
Gatineau, Qc, Canada eh!
  • wiredgeorge
  • wiredgeorge's Avatar
Re: turn signals not working
10 Aug 2007 04:36
#162960
Check the fuse... Also check the main fuse. It is probably not the fuse but is likely a bad connection somewhere in either the hotwire to one of the signals or a ground. This will cause all four turn signals to not function. You might also have a bad flasher relay. A better question is how to troubleshoot turn signals. This has been talked about in many threads so you should be able to find the needed info if you start searching through older threads.
  • SebRain77
06 Sep 2007 14:42
#169025
fixed the problem over the weekend.... turns out a bad connection somewhere.... all is good now!
  • SebRain77
06 Sep 2007 14:42
#169026
