kz1300 not fireing on 1n5
- Rutor1
09 Aug 2007 08:55
have check the wiring between the coils and the igniter ,coils are working and was wondering if the igniter pack could cause the problem in only the two to not get spark?
- loudhvx
Re: kz1300 not fireing on 1n5
09 Aug 2007 09:01
If you know for sure it's 1 and 5, maybe try swapping coils around and see if the problem follows the coil.
Don't 1 and 6 go to the same coil? I always thought it was 1,6 2,5 and 3,4 that shared coils.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Rutor1
09 Aug 2007 09:04
ah duh yur right 1n6 and i tryed swapin the coils also and it stays only on 1n6 wiring read ok to betweencoils and to igniter
- Rutor1
Re: kz1300 not fireing on 1n6 ????
09 Aug 2007 09:06
got me stumped at this time . have not check the igniter it self thats what i will do next but was wondering if that could be it like only not working on those two but good still for the rest ????
Post edited by: Rutor1, at: 2007/08/09 12:08
- loudhvx
09 Aug 2007 09:11
Alright, so the problem is on 1 and 6, and you swapped coils and the problem stayed on 1 and 6. That means it's most likely the igniter, but could also be the pickup on the crank. Can you ohm-out the pickups?
1981 KZ550 D1 gpz.
Other links.
Other links.
- Rutor1
09 Aug 2007 09:13
ok have not tryed that yet what should they ohm out at ??
- loudhvx
09 Aug 2007 09:24
There should be six pickup wires at the igniter, 3-pairs, and they hopefully will be on their own connector. You can usually identify them because they will be thinner than the other wires to the igniter. Each pair should be around 300 to 500 ohms. (I'm assuming the pickups are similar to other KZ pickups from the era.) I'm not sure what the color combos will be for the pairs.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Rutor1
09 Aug 2007 09:32
sure appreciate the help now I have too find out if thats the prob ....
