Starter/flywheel woes
- jp650sr
08 Aug 2007 15:46
The starter on my 650sr is having some troubles. originally i thought the teeth on the starter were bad, but i pulled it, and both it and the flywheel's teeth are fine. i took the starter apart, and the gears on the inside are also fine. the problem is... when the bike is cold, trying to use the starter causes a bunch of clanging and grinding noises like the teeth dont make good contact. however, when the bike is warm, i can just tap the start button and it fires up. i just kick start it because its easy enough, but i figured when i got around to it, it would be an easy starter swap fix. if the starter is fine, and the flywheel is fine, where is the grinding coming from?
- jp650sr
Re: Starter/flywheel woes
08 Aug 2007 15:50
after reading another post, it sounds a lot like what was said about a bad stater clutch. think thats my issue?
- RonKZ650
08 Aug 2007 16:24
I'll bet it is in the starter clutch. I'd leave it be because repair means removing the engine from the frame. Guys have done it without removing the engine, but it would not be easy laying on your back in a pool of oil.
