accel coils
  • babber
  • babber's Avatar Topic Author
accel coils
08 Aug 2007 15:03
#162567
Hi,I'm new to the forum but I've been reading it for awhile and I know someone here can help.I have an 81 kz750e with the stock ignition but bad coils and I have a pair of accel coils 140403 that are both showing .9 ohms primary resistance,can I use these on the bike?I did put them on the bike and it fired right up and seamed to run good but not being sure if it would hurt the bike I didn't ride it.Any insight would be great.
Thanks
  • steell
  • steell's Avatar
Re: accel coils
08 Aug 2007 17:37
#162601
.9 OHMS equals a "lot" of current flowing through the igniter to ground :woohoo:
Probably let the magic smoke out of the igniter rather soon :)
What does the manual specify? 2.2 - 2.4 ohms?
I just checked and it says "about 2.25 ohms"
  • JR
  • JR's Avatar
Re: accel coils
08 Aug 2007 18:13
#162625
Coils can be costly but beware - ignitors cost an arm and a leg.
  • loudhvx
  • loudhvx's Avatar
Re: accel coils
09 Aug 2007 00:39
#162699
.9 is way too low for the stock ignitor. .9 is a CDI coil. You do not have a CDI ignition.
If you blow the ignitor, you can make one for about $35.
  • Paling1
  • Paling1's Avatar
Re: accel coils
09 Aug 2007 02:47
#162704
Do you mind explaining how to make the ignitor for $35?
:cheer: :)
KZ700-A1 (1984)
525 chain conversion; Dyna 2,2 ohm coils; Taylor plugwires; Stainless steel ZR-7 exhaust ; Remus muffler.
Plans: GPZ cams, ported head, 17 inch wheels, EFI....
  • loudhvx
  • loudhvx's Avatar
Re: accel coils
09 Aug 2007 07:41
#162745
:cheer: :)
Sure, but it's only for mechanical-advance type electronic ignitions.
www.geocities.com/loudgpz/GPZgmHEImod.html
