KZ 650 B or C
- Qdude
- It is all good.
KZ 650 B or C
03 Aug 2007 14:36
I see that there are regulators available for kz 650 B models at oregonparts.com
Will this regulator work for my 650C as well?
The regulator has the same color code green brown black w/yellow.
It seems that they should be interchangeable.
Q
Q
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- loudhvx
Re: KZ 650 B or C
03 Aug 2007 18:15
B and C for 1977 used the same regulator as long as it's the green/brown/black wire regulator (and it's also seperate from the rectifier).
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
