will this
  • quader98
  • quader98's Avatar Topic Author
will this
29 Jul 2007 07:49
#160492
im in desperate need of a wiring harness,will this work on mine?i believe it comes off of an ltd.i did a parts check on th kawi sight and it says its only for the ltd.what would be the difference between the ltd and the 750E
linkety link
Post edited by: quader98, at: 2007/07/29 11:57
Post edited by: quader98, at: 2007/07/29 12:04
Post edited by: quader98, at: 2007/07/29 12:05
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
  • loudhvx
  • loudhvx's Avatar
Re: will this
29 Jul 2007 08:05
#160495
No can see the post unless they scroll way down. Use the URL button for board code to make it like this:
linkety link
If you hit the "quote" button, you'll see what I did, or, hopefully a mod will come in and fix your link.
Anyway, the LTD frame is different so the harness will be different. The wires will be different lengths and some components may be in different locations. Also, any 25 year old harness may have the same problems yours does. Most harnesses have broken wires in the same areas... like near the steering column.
  • quader98
Re: will this
29 Jul 2007 09:08
#160510
thanks for the help loud tried to make it work ended up just copying yours.the harness i have is just spliced all over the place and one wire has no insulation on it just tape..im not gonna bid on it.the bike is nowhere close to needing the harness right now,not gonna rush it
Post edited by: quader98, at: 2007/07/29 12:16
82 GPZ 750 R1
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: will this
29 Jul 2007 09:17
#160511
If you've got a colored version of the wiring diagram for your bike, the desire/time/ability to do it, you could always fab another wire harness with all NEW wiring and connectors for your bike and be (at least electrically) trouble-free. :)
A bonus is you that can remove a lot of redundant and unused wiring/connectors that Kawi installed to simplify your "new" harness.
There are quite a few members here who have already done this on their bikes. And I'm sure they, as well as loudhvx would be more than happy to guide you through it if you have any questions or probs. ;)
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • Virii
  • Virii's Avatar
  • I like cheese
Re: will this
29 Jul 2007 09:31
#160517
Yes, this is the way to go, if you ask me. It takes some time and planning but you'll be better off for it, in my opinion. Upgrade the wire gauge in some areas as you go along.
Tess: 1977 KZ650-C1. VM24, 97.5/15/3rd. Dyna-S. Stock exhaust, coil mod performed, BR7EIX.
Angel: 1982 GPz550. Stock. DR8EIX.
  • Mark Wing
  • Mark Wing's Avatar
Re: will this
29 Jul 2007 09:32
#160519
I think the difference is that the LTD's have running lights on the blinkers.
Mark
Yorba Linda Cal.
  • quader98
Re: will this
29 Jul 2007 15:19
#160570
yea i think building my own is the way im gonna have to go.thanks for the help...i will be picking your brains
82 GPZ 750 R1
