Self cancelling turn signal??
- matts750
28 Jul 2007 14:42
I came across a turn signal cancelling box for a '81 KZ and bought it with plans to install it on my '80 KZ750. Of course, my Clymer's manual has very little information about the system and nothing that helps. Anyone have a self-cancelling turn signal who can tell me where it goes and possibly what other parts I may need to make it work?
- Samwell
Re: Self cancelling turn signal??
28 Jul 2007 16:01
matts750 wrote:
do you know what kind of '81 KZ it came off of? Once you know that, kawasaki.com will have parts diagrams, you could nose around and see what else that bike has. If you can find one, the kawasaki shop manual would shed a little light on it.
hope that helps...Sam
- Virii
- I like cheese
28 Jul 2007 21:03
Is that a mercury switch, out of curiosity? I assume so but *shrug*
Tess: 1977 KZ650-C1. VM24, 97.5/15/3rd. Dyna-S. Stock exhaust, coil mod performed, BR7EIX.
Angel: 1982 GPz550. Stock. DR8EIX.
- RetroRiceRocketRider
28 Jul 2007 22:37
Welcome to KZr matt.
I know the one on my ZN is operated by distance traveled and is controlled electrically in some fashion, so I'd imagine the one you bought operates the same way.
IMHO though, they are more of a nuisance than a help.
Mine cancels as I'm ENTERING the turn lane rather than AFTER I complete my turn, and at freeway speeds will cancel before I've completed a lane change.
I would yank it off and toss it as far as I could throw it. But I figure if I ever decide to sell my bike, it might fetch more money if the buyer knows that everything OEM is still intact and functional. So I simply unplugged it and left it bolted there to the bottom of the battery box.
Post edited by: RetroRiceRocketRider, at: 2007/07/29 01:37
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- loudhvx
29 Jul 2007 07:04
Yeah, the distance-measuring ones blow.
I use one I made based on a time delay only. I like the time delay at about 45 seconds. It's just about right for a Chicago traffic light, but would be a little long on a highway lane-change... but better than driving 100 miles with the blinker on
When you say "box", I assume you mean the control box. Then you still need the handle bar switch assembly (it's pretty big) for it to self cancel. And you need a distance-sensor in the speedo gauge. But it's possible you can leave off the distance sensor and maybe it'll work on time-delay alone.
The actual flasher appears to be a normal flasher unit. You may want an electronic one, though, for a more consistent flash rate.
Click onto the KZ550C pdf file here:
kzrider.com/component/option,com_docman/...w/gid,159/Itemid,49/
It's the wiring for a KZ550 C which has the system on it.
Post edited by: loudhvx, at: 2007/07/29 10:11
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- matts750
29 Jul 2007 11:27
I've heard some people who like them and others who don't. I frequently forget to turn the blinker off. It would be great to find an aftermarket self-cancelling signal that can be adjusted for time and/or distance.
- KaZooCruiser
29 Jul 2007 12:13
matts750 wrote:
Have you given any thought to installing an audible monitor (noise horn)? Sometimes they are hard to hear, but they can help when the signal lights aren't quite enough.
. . . I frequently forget to turn the blinker off . . .
- Virii
- I like cheese
29 Jul 2007 13:42
I recently upgraded to LED's throughout and hooooola, it's nearly impossible to miss it when I forgot to turn them off. That nuclear yellow indicator on my bars is enough to remind me.
If you go that route and you do any nighttime riding, you may want to consider fitting secondary smaller output gauge led's or a lighting switch to cut them entirely. The output of the actual turn signals will remind you at night, I'm sure.
I had some mercury based turn signal cancels on my XS650. Maybe transplanting something along those lines might be a more palatable alternative?
- matts750
29 Jul 2007 15:50
I'm not sure what type of switch is in this module. It's a stock "turn signal operating unit self-cancelling" that came of a 81 KZ750.
Searching around, I found a self-cancelling turn signal, Kisan Signal Minder, that allows you to set the time at 8, 16, or 24 seconds and links up to the brake to suspend timing until after it's been released to avoid it turning off at a stop light. Of course, I haven't found any specs to indicate it will fit anything as old as a '80 Kawaski.
- Qdude
- It is all good.
31 Jul 2007 14:19
Virii wrote:
How much did that upgrade run you, if you don't mind me asking. I was considering doing it.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
