Starter Question
  • 13thlevel
  • 13thlevel's Avatar Topic Author
Starter Question
26 Jul 2007 14:53
#159899
Should there be continuity from the starter lead terminal (the post on the starter) to ground? I would think not.
Post edited by: 13thlevel, at: 2007/07/26 17:54
  • The Milkman
  • The Milkman's Avatar
Re: Starter Question
26 Jul 2007 15:42
#159917
Actually there well be a little continuity, not sure of the ohms though. Your starter will still be making contact with ground through the brushes. You are just reading the ground circuit in the starter.
