hazards and blinker issue
- furby1184
19 Jul 2007 21:29
my hazards dont blink at all and my blikers blik erratically. what could cause this on a 1979 kawaski kz650?
1979 KZ 650B pod filters, 4-1 kerker.
- RetroRiceRocketRider
Re: hazards and blinker issue
19 Jul 2007 21:46
Welcome to KZr furby1184.
The hazard lights and turn signals each have their own relays (same style relay for each), so I'd suggest checking those first to see if the one for the hazard lights is shot or disconnected.
If a bulb in one of the signals is burnt out, it can cause the others to flash in a non-uniform (erratic) sequence.
Be sure to check all the wiring and connections to the signals, as a loose connection/ground or short could be the combined simple cause.
Post edited by: RetroRiceRocketRider, at: 2007/07/20 00:48
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- JMKZHI
Last edit: 03 Dec 2008 10:04 by JMKZHI.
- Qdude
- It is all good.
20 Jul 2007 08:07
That is true. It was explained to me that the relays need a certain amount of current running through them to properly heat the part that breaks the curcuit. With more modern bulbs, it is possible that the currents get tweaked, resulting in a malfuntioning blinker curcuit.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- furby1184
21 Jul 2007 11:31
thanks guys ill try that but my electrical is all half-assed with electrical tape im gonna butt them all together. your help was very appreciated
- cannibal440
26 Jul 2007 11:48
i was having the same trouble. i went and bought new flasher relays and replaced one bad bulb. problem solved. i took one of the old relays apart and it was full of rusty chunks.
