Speedo freezes and wont return to 0.
- ricerocket
19 Jul 2007 18:34
I recently purchased a guage cluster from ebay.It looks great tach works ok but the speedo when i ride and slow down it stops at the high speed and does not return to 0.
Any suggestions on cleaning?I opened the back up and blew out the cob webs.But still does same thing.
Any help would be great.
- KZ_Rage
- Kentucky Bourbon Barrel Ale
Re: Speedo freezes and wont return to 0.
19 Jul 2007 18:45
How bad was the cob webs? For real question, those little buggers can really build some nests in there!
You may have just discovered why it was on eBay though too unfortunately...
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- ricerocket
19 Jul 2007 18:51
they were pretty bad.I blew it out best i could with compressed air.Is there a lube you can use for gauges?Internal?
- KZ_Rage
19 Jul 2007 19:03
Pretty sure the gauge you have isn't the one with the easy to remove housing. Any more work on the gauge and you'll have to open it all the way. Can be a PITA to do and then get it back together where it will look reasonably like it did before you took it apart. Don't just try spraying WD40 or something in there or it will end up on the lens for sure.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
1984 KZ550F2 SOLD!
- fixer5000
20 Jul 2007 01:55
1978 kz650b pretty much stock
massachusetts
massachusetts
- jeffreygp
20 Jul 2007 03:32
Hello,Before opening it try putting baby oil(used this not to hurt any plastics in there)into the drive where the cable goes n rotate it a couple dozen times. it work on my sluggish speedo n noisy tach.If it doesn't work opening it would be the option.
