Bare bones wiring in my 77 kz650
- oldkaws4ever
- Have no regrets...... You only live once.
17 Jul 2007 22:22
ok, i have had my 650 about 2 years now and am ready to finish my cafe transition. But i have always had electrical issues from day one, usually blowing the main fuse when it was wet or damp out. So now i wanna sympfully the wiring. I just want the bare minumum to make her roar to life again. Here is what the bike has done to it, pure kick start, stock Gauges and idiot lights, turn signals and halogen head light. Now what i wanna know what kind of electrical switches can i use to replace my almost non existant ones on the handle bars. The previous owner broke the kill switch and just hard wired the two wires together, but in the process of taking this thing apart and moving it around i have completely lost the right side handlebar switch. Im going to try to addapt one off a 74 z1 900 i have laying around, i dont know of it will work( any ideas or thoughts?) But if that dont work does any body know were i can get swiches that will work. I also relocated the ignition switch to the left side cover.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- mariozappa
Re: Bare bones wiring in my 77 kz650
18 Jul 2007 05:35
there was this thread not too long ago.
kzrider.com/component/option,com_joomlab...,4/id,156144/#156144
1977 KZ650C1
and the KZ650/KZ750 Conversion
- wiredgeorge
18 Jul 2007 05:50
You asked about a bare-bones harness then mention idiot lights, gauges, turn signals, etc? AND want to use the wrong switches? OK... To wire the thing start with stuff that allows you to get the bike running... start with the AC lines from your stator to the regulator and rectifier.
There are a couple kinds of stator (generators) on a 650. I am not sure which you have. Does it have three yellow wires? Do you have a combined regulator/rectifier or separate? The wiring for this stuff is critical and you should first design this wiring (lay it out) and the fuse box. Then a wire will go from your fuse box to an ignition switch of some sort.
Out of the ignition switch, you will have a number of "legs". One of the legs will go to the rear tail light directly and one to the right switch where it will run through the kill switch. This line will provide power to the coils eventually. Last, there will be yet another line that may or may not run through the right switch depending on whether you have an on/off switch there for the headlight. This line will SPLIT and run back through the fuse box through the two smaller fuses there and become two fused/switched subcircuits. The color is generally BLUE for one and BROWN for the other. The blue will handle the headlight and brake light (not the running light in the brake which was the red wire directly off the ignition switch). The BROWN circuit will handle your horn, the turn signals and provide feedback voltage for the regulator or regulator/rectifier.
On a Kaw, the main ground is generally on the engine cases above the kick start. If you trace this ground it goes into the main harness and snakes out through the engine bike and also hooks to the NEG terminal on the battery.
There are generally two sub harnesses in front and one in back. The front will consist of the idiot light subharness where connections run from various switches to the idiot lights; like the neutral light and oil light and sometimes a rear brake light. The other subharness will connect the wires from the headlight (hi beam, lo beam and ground to the headlight). The rear sub harness plugs into the main harness and comess off the brake light and rear turn signals.
You don't need a "bare bones" harenss as you have EVERYTHING hooked up with the exception of your starter and the only real "mod" is that you have moved the ignition switch. Again, I recommend you buy a stock ignition switch and put it where it was orignally and use a STOCK wiring harness and STOCK handlebar switches... I know that you didn't want to hear this but if I were to draw a new wiring harness for you it would look like the old one only have the new switches hacked in with longer wires for the relocation of the ignition switch and hacks to accomodate the different functions on the handlebar switches.
- oldkaws4ever
18 Jul 2007 22:37
the more i have been thinking about it i want to eliminate the gauges and idiot lights an such. I just didnt know it would envolve as much to keep the stock gauges and such. I hope this helps in your suggestions to me. Thanks
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
